RMP (EtherCAT)
Open, powerful, and economical PC-based EtherCAT soft motion controller for OEM machine builders. The RapidCode API allows developers to quickly create machine control applications in C++, C#, or VB.
Sections
  • Getting Started - Install, configure, and learn the basics of our motion controller.
  • Software APIs - use these APIs to access the RMP Motion Controller.
    • RapidCode API - Our powerful and intuitive Application Programming Interface (API) that allows developers to quickly create machine control applications in C++, C#, or VB.Net.
    • RapidSequencer API - use our proprietary scripting language to easily program the entire machine program or sub-routines using RMP Motion Controller into the RTOS to achieve real-time deterministic performance.
  • Software Tools - these tools can be used to troubleshoot, diagnose, and/or configure the RMP.
    • RapidSetup - Our easy-to-use utility for configuration, homing, tuning, commanding motion, and troubleshooting.
  • Premium Features - these are extended RMP features that require special documentation.
  • Other
    • FAQ - Explore some of the most commonly asked questions.
    • Sample Apps - Use them to better understand how to use our RapidCode API.
Export as PDF
Copy link
